After last version of FLUKA & flair updated on cluster, I did make a try with a test input based on “basic” template from flair calling Low-PWXS from JEFF library. The same file is running perfectly well on my lap top but on the cluster I get the following error message from .out file:
ERROR: could not load neutron cross section for isotope Z=6 A=12 m=0
Abort called from KHPNLOAD reason Error loading neutron cross section for isotope Run stopped!
STOP Error loading neutron cross section for isotope
From .log file I get this:
Note: The followinf floating-point exceptions are signalling: IEEE_UNDERFLOW_FLAG IEEE_DENORMAL
STOP STOP: FLUKA ABORTED
On both, FLUKA version is 4-3.3 and FLAIR version is 3.2-4.5
JEFF, ENDF and JENDL librairies are duly installed on /flukapath/data/neutron/ directory
I am not administrator on the cluster, so I did not install anything and I don’t know if there is any trick not explained on the librairies downloading page for a cluster installation.
On my laptop, the OS is from Ubuntu 20.04.5 LTS.
On the cluster it is
Ardi433.flair (2.7 KB)
Ardi433.inp (2.7 KB)
Ardi433001.log (175 Bytes)
Ardi433001.out (26.5 KB)
Any help will be greatly apprieciated.
J-B.
