Hi guys, new user of Fluka/Flair here. I am trying to compile at the HPC (linux platform) of my work computer. I have downloaded and extracted the geoviewer. Then I go inside the extracted folder and change the input line of the makefile ‘DESTDIR’ to the folder where I extracted the geoviewer. The reason I do it because, I do not have admin permission to create files at /usr/local/flair.
First I type make -j 8 and it creates all these files
and then I do: $ make install
then it gives: <flagtail:flair-geoviewer-3.2 >make install
make -C viewer
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/viewer’
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/viewer’
make -C farm
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/farm’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/farm’
make -C geometry
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/geometry’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/geometry’
make -C data
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/data’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/data’
make -C graph
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/graph’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/graph’
make -C math
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/math’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/math’
make -C tool
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/tool’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/tool’
make -C xdraw
make[1]: Entering directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/xdraw’
make[1]: Leaving directory ‘/evtdata/radtrans/Raj/Flair/flair-geoviewer-3.2/xdraw’
mkdir -p /evtdata/radtrans/Raj/Flair/Install_Files
mkdir -p /evtdata/radtrans/Raj/Flair/Install_Files/fonts
install -m 644 geoviewer.so /evtdata/radtrans/Raj/Flair/Install_Files
install -m 755 usrbin2dvh /evtdata/radtrans/Raj/Flair/Install_Files
for f in AUTHORS BUGS README LICENSE; do
install -m 644 $f /evtdata/radtrans/Raj/Flair/Install_Files/$f.geoviewer;
done
for f in fonts/*.tga;do
install -m 644 $f /evtdata/radtrans/Raj/Flair/Install_Files/fonts; \
I see some files are generated in the destination folder, but not the executable. I have checked that the python installer that I had has tkinter.
I don’t fully understand what’s causing the error. I have only extracted the geoviewer source file. Should I also install the data file in the same directory?
