Hi team,
I am facing the below error, while assigning a material to a region and the fluka crashes with the below message:
File "/home/opinto/flair-3.3/flair.py", line 3482, in <module>
main()
File "/home/opinto/flair-3.3/flair.py", line 3446, in main
flair = Flair(root, project) if gui else None
File "/home/opinto/flair-3.3/flair.py", line 733, in __init__
self.tabs.create(self)
File "/home/opinto/flair-3.3/flair.py", line 390, in create
self.changePage(flair.project.page) #<--- must ensure that exists
File "/home/opinto/flair-3.3/lib/Ribbon.py", line 1166, in changePage
if page.invalid(): page.refresh(page._invalid)
File "/home/opinto/flair-3.3/InputPage.py", line 6311, in refresh
self._fillRuns()
File "/home/opinto/flair-3.3/InputPage.py", line 6348, in _fillRuns
self.runCombo.set(self.runCombo.get(0))
File "/home/opinto/flair-3.3/lib/tkExtra.py", line 3987, in set
if invoke: self.invoke()
File "/home/opinto/flair-3.3/lib/tkExtra.py", line 3940, in invoke
self.command()
File "/home/opinto/flair-3.3/InputPage.py", line 6699, in runChanged
self.showCards(self.tags, self.filters)
File "/home/opinto/flair-3.3/InputPage.py", line 6636, in showCards
self.editor().displayCards(cardlist)
File "/home/opinto/flair-3.3/InputPage.py", line 2858, in displayCards
self.addCard(None, card)
File "/home/opinto/flair-3.3/InputPage.py", line 2614, in addCard
cw = CardWidget(self, card, ypos)
File "/home/opinto/flair-3.3/InputPage.py", line 417, in __init__
self.create(ypos)
File "/home/opinto/flair-3.3/InputPage.py", line 514, in create
datatxt = str(self.listValue(dat)) + _TRIANGLE_DOWN
File "/home/opinto/flair-3.3/InputPage.py", line 643, in listValue
self.card.addInvalid(int(w))
TypeError: int() argument must be a string, a bytes-like object or a real number, not 'function'
For example if I uncomment the below lines in my .inp file then I face the above error:
*..+....1....+....2....+....3....+....4....+....5....+....6....+....7..
* SS316L: AISI316L Stainless Steel taken from Datasheet from A. Perillo
*MATERIAL , , , 7.99, , , ,SS316L
*COMPOUND , -0.65495, IRON, -0.17, CHROMIUM, -0.12, NICKEL, SS316L
*COMPOUND , -0.025, MOLYBDEN, -0.02, MANGANES, -0.0075, SILICON, SS316L
*COMPOUND , -0.00045, PHOSPHO, -0.0003, SULFUR, -0.0008, CARBON, SS316L
*COMPOUND , -0.001, NITROGEN, , , , ,SS316L
I downloaded the FLUKA src file to my local machine in .tgz format
