Dear professors:
I’m working on JUNO LS mixed with certain percentage of Te. With default PRECISIOn, there is no additional physics or transition. Upon running, errors occur during the initialization. I have uploaded the codes and the descriptions for the error. It works only if I removed the element Te even if it is a default material. It will break down if Te is elemental or compound. I wonder how to solve this problem. Thank you in advance!
experiment.flair (3.6 KB)
Dear @hanhechong,
This problem has already been addressed several times on the forum. As an example, have a look at this thread and its solution Low energy neutron xsec not found for some media - #2 by horvathd
Dear @hanhechong,
You will also need to take a look at this post since Te is not pre-defined.
Dear @hanhechong ,
As @amario pointed out: Generally the missing low neutron cross section is fixed by using a LOW-NEUT card, but the number of available cross sections is limited to the ones linked by @Mihaela_Parvu, and tellurium is not among them.
But with the latest FLUKA 4-3.0 release, you can use the new point-wise low energy neutron cross section data, which contains many more isotopes including Tellurium.
For more information see:
- 10.2. Pointwise transport — FLUKA Manual
- 7.22.43. LOW-PWXS — FLUKA Manual
- FLUKA libraries for low-energy neutron pointwise interaction cross sections | The official CERN FLUKA website
Thank you so much for useful information!
Thank you so much! However, after I get the newest release and install the necessary packages, I can not find this LOW-PWXS in flair?
Thank you so much for useful information as well!
Did you upgrade flair as well?
I forgot to upgrade at that time. Thank you for reminding.
