eskordis
(Eskordis)
22 September 2020 16:46
1
Hi,
I wanted to report that the expressions (for example “=3*4”) are not updated when the cards are inside conditions such as #if #else etc.
Attached you can find an example of the input.
I am using flair version 3.1.4
Thank a lot for your efforts
Kind regards
Lefteris
ExpressionCalculations.flair (942 Bytes)
ExpressionCalculations.inp (1.0 KB)
vasilis
(Vasilis Vlachoudis)
28 September 2020 07:20
3
Thanks Lefteris,
I have to check, I will let you know. You are right it should work also inside the conditionals on the branch that it is active.
Vasilis
vasilis
29 September 2020 08:09
4
Hi Leftheris,
I found the problem and correct it. flair was not refreshing the internal state (active/disabled) of a card when a #define
or #undef
card was changed (add/delete/disable/enable…)
Now it is correct in the dev version.
