Fail to start flair
Hello David,
I have a unique issue. I have installed flair3.2 and flair-geoviewer-3.2 on ubantu20.04
‘check-fluka.py’ results:
Checking python
Version: 3.8-10 ok
Checking python tkinter module
tkinter found
Checking tk library
Tk Version= 8.6 ok
Checking python imaging
python-imaging-tk installed
Checking gnuplot
gnuplot 5.2.8 ok
Checking memory
Ram: 8105832 kb ok
Swap: 2097148 kb ok
Checking CPU
CPUs: 4 ok
Clock: 3408 MHz ok
Arch: x86_64
Checking X11
X11 dimension: 2089x1219 ok
X11 depth: 24 ok
Checking flair
flair directory: /usr/local/flair
flair version: 3.2-0
Checking flair-geoviewer
flair version ok (same or higher than 3.0-7)
flair-geoviewer version 3.2-0
flair and geoviewer version match
Checking gfortran
gfortran version 9.4.0
gfortran function properly
Checking FLUKA
FLUKA directory: /usr/local/fluka
FLUKA Version= 4-3.0
/usr/local/fluka/bin/fluka exists
/usr/local/fluka/bin utilities exists ok
============================== ERROR ==============================
{flukadir}/bin/lfluka -o testfluka doesn’t compile/link properly
	Please ensure you have the correct version of fluka with the appropriate compiler
Appreciate your input.
Thanks
Sun chuqing
Sorry for that, there was a problem in the build process.
Please try to download again and re-install.
If you used the automatic installation via the repo re-install the new public repository key “flair.gpg” again as it shown in the download instructions
