Dear Junjie,
yes, FLUKA is now successfully installed. If there is still a problem in Flair, try to delete the directory of the manually installed FLUKA. Afterwards there should not be any issue.
Dear Junjie,
Hi David,
I changed FLUKA Directory in flair to /usr/local/fluka/bin,It seems to have solved my problem.
When I open a simulation, an error “Unable to load usrbin detector” is displayed, but I can click START to run normally, and I can get the result diagram of USRBIN in PLOT.
Could you tell me if this error is a software error or an error in my simulation file?
Dear Junjie,
You get that error message, when the Geometry tab has a layer to show an USRBIN result, but the file is not available. After the first run and merge, the file should be created, and you won’t get the error next time.
Thank you very much for your answer to my question.
