Finishes with DOGEBD error
Dear FLUKA users,
I was performing a simulation in which I was trying to include gaussian broadening. While using the DETGEB card, the results of the simulations returned a runtime error, and the error file, log file and a screenshot of the input card is as follows
Error File: PIPA-2ndStep-9724027.err (802 Bytes)
Log File: PIPA-2ndStep-9724027.log (13.0 KB)
Screenshot:
Please suggest how to solve this issue.
Thanks,
Dear Krish,
could you share your input file as well to have a closer look? Thanks!
Sure David,
Here it is…
PIPA-2ndStep-9724.inp (5.4 KB)
I am also attaching the Fortran code for this, I hope it helps!..
source_newgen_photon_collExit.f (19.6 KB)
Thanks for the help!
Dear Krish,
thank you for the input file and source routine.
For the latter I would need also the PIPA-Step1_19524.dat file containing the photon’s phase space in order to use it, could you provide it to me?
I have tried for the moment to run your input with a simple photon as source and I can not reproduce your error. I have run with FLUKA4-4.1, could you sent me also the .out of the run you did?
Last point, I see that in your input file you define in the BEAM card PROTON as source, but then you upload photon with the .dat file. I suggest to set an energy in the BEAM card higher than the maximum energy of photons saved in the phase space. Have a look to note 3 in the SOURCE card - manual.
Giuseppe
