Hello,
I have a problem with the installation of flair 3.2.
The problem occurs during the installation on lxplus, while I managed to get it working locally (MacOS).
What I do step by step:
Install Flair:
I untared flair
cd into the folder. For me in the following position:
/afs/cern.ch/user/m/mibauer/private/Software/flair-3.2
command: make
Install Flair Geoviewer:
Untared geoviewer
/afs/cern.ch/user/m/mibauer/private/Software/flair-geoviewer-3.2
command: make
save in a variable my path to flair:
FPATH=‘/afs/cern.ch/user/m/mibauer/private/Software/flair-3.2’
The path was saved successfully, which was tested with
echo $FPATH
Then I type (within the geoviewer directory) :
make install DESTDIR=$FPATH
Try to open Flair
I switch to the flair directory and enter:
./flair
The following error occurs:
File “./flair.py”, line 3386, in
initialize()
File “./flair.py”, line 3326, in initialize
inputs.init()
File “/afs/cern.ch/user/m/mibauer/private/Software/flair-3.2/inputs.py”, line 94, in init
fluka.init()
File “/afs/cern.ch/user/m/mibauer/private/Software/flair-3.2/fluka/init.py”, line 59, in init
if not cardini.read(filename): return False
File “/opt/rh/rh-python36/root/usr/lib64/python3.6/configparser.py”, line 697, in read
self._read(fp, filename)
File “/opt/rh/rh-python36/root/usr/lib64/python3.6/configparser.py”, line 1015, in _read
for lineno, line in enumerate(fp, start=1):
File “/opt/rh/rh-python36/root/usr/lib64/python3.6/encodings/ascii.py”, line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: ‘ascii’ codec can’t decode byte 0xc2 in position 1187: ordinal not in range(128)
Can you help?
I use
Python 3.6.12
gcc (GCC) 9.2.0
I already found this topic:
and tried the command
LC_ALL=en_US.UTF-8 flair
which did not help.
Thanks,
Michael
