FLUKA: 4-5.2
Flair: 3.4-5.4
Operating system: macOS Sequioa 15.7.2
Dear FLUKA/Flair team,
I have recently updated my macOS installation to:
FLUKA : 4-5.2
Flair : 3.4-5.4
Geoviewer : 3.4-5.4
Python : 3.12.14
Tk/Tcl : 8.6
Platform : darwin
The installation is now stable and Flair/Geoviewer are working correctly after resolving a separate Bus error: 10 issue.
However, I am still seeing a persistent geometry-view behaviour that appears to match the unresolved issue mentioned in this thread Flair crashes in Geometry tab (macOS) — post #12.
The issue is that, when I move/drag the geometry view, the viewport lines move immediately, but the geometry itself does not follow continuously. Instead, the geometry is redrawn only afterwards, when the movement is stopped.
This is particularly apparent when panning or moving the viewport position. The interaction therefore feels as though the viewport overlay is being updated first and the actual geometry render is catching up afterwards.
On the same machine, with Flair/Geoviewer 3.4-5.2, the geometry followed the mouse smoothly and continuously, so this appears to be a change introduced in the newer versions rather than a general macOS performance limitation.
For completeness, my current Flair diagnostic information is:
version : 3.4-5.4
geoviewer : 3.4-5.4 False
revision : df6929e3
last change : Mon Jun 1 10:23:06 2026 +0200
kleidi : 1790831107.300
python : 3.12.14 (main, Aug 14 2026, 23:56:42) [Clang 17.0.0 (clang-1700.0.13.5)]
tk : 8.6
tcl : 8.6
numpy : 2.5.3
pydicom : 3.0.2
platform : darwin
There is no Python traceback associated with this issue.
Could you please confirm whether this delayed redraw behaviour is expected in 3.4-5.4, or whether it is a known regression? If there is a configuration option or workaround to restore the continuous redraw behaviour seen in 3.4-5.2, I would be very interested in trying it.
Many thanks for your help.
Samuel
