Indeed I did update all the Macports.
I did try the post you referred to before and tried it again but it did not change Flair behavior. Thanks again for your help. Please find bellow the output of the commands.
sw_vers -productVersion: 15.6.1
pkgutil —pkg-info=com.apple.pkg.CLTools_Executables: 16.4.0.0.1.1747106510
xcodebuild -version: xcode-select: error: tool ‘xcodebuild’ requires Xcode, but active developer directory ‘/Library/Developer/CommandLineTools’ is a command line tools instance
gfortran -v: Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/aarch64-apple-darwin24/13.4.0/lto-wrapper
Target: aarch64-apple-darwin24
Configured with: /opt/local/var/macports/build/gcc13-a82e608c/work/gcc-13.4.0/configure --prefix=/opt/local --build=aarch64-apple-darwin24 --enable-languages=c,c++,objc,obj-c++,lto,fortran,m2,jit --libdir=/opt/local/lib/gcc13 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-13 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-13 --with-gxx-include-dir=/opt/local/include/gcc13/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-isl=/opt/local --with-zstd=/opt/local --enable-checking=release --disable-multilib --enable-lto --enable-libstdcxx-time --with-build-config=bootstrap-debug --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --enable-host-shared --with-darwin-extra-rpath=/opt/local/lib/libgcc --with-libiconv-prefix=/opt/local --disable-tls --with-gxx-libcxx-include-dir=/opt/local/libexec/gcc13/libc++/include/c++/v1 --with-pkgversion=‘MacPorts gcc13 13.4.0_1+stdlib_flag’ --with-sysroot=/Library/Developer/CommandLineTools/SDKs/MacOSX15.sdk
Thread model: posix
Supported LTO compression algorithms: zlib zstd
echo $PATH: /Users/alain/EGSnrc/EGSnrc/egs_home/bin/osx:/Users/alain/EGSnrc/EGSnrc/HEN_HOUSE/bin/osx:/Users/alain/EGSnrc/EGSnrc/HEN_HOUSE/scripts/bin:/Library/Frameworks/Python.framework/Versions/3.12/bin:/Library/Frameworks/Python.framework/Versions/3.11/bin:/opt/local/bin:/opt/local/sbin:/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/opt/X11/bin
port echo requested:
Warning: port definitions are more than two weeks old, consider updating them by running ‘port selfupdate’.
gcc13 13.3.0_2+stdlib_flag
gdb 15.1_015.1_0
gdb 16.3_0 16.3_0
ghostscript 10.05.1_0+x11
ghostscript 10.06.0_0+x11
gnuplot 6.0.3_0+aquaterm+luaterm+pangocairo+qt5+wxwidgets
gnuplot 6.0.3_2+aquaterm+luaterm+pangocairo+qt5+wxwidgets
py311-matplotlib 3.10.6_1+tkinter
py311-pip 25.1.1_0 25.1.1_0
py311-pydic 3.0.1_0m 3.0.1_0
py311-scipy 1.16.2_1+accelerate+gfortran
py312-matplotlib 3.10.6_1+tkinter
py31@25.1.1_0-pip 25.1.13.0.1_00
py312-pydicom 3.0.1_0
py312-scipy 1.16.2_1+accelerate+gfortran
py313-matplotlib 3.10.3_0+tkinter
py313-matplotlib 3.10.6_ 3.0.1_0+tkinter
py313-pydicom 3.0.1_0
py313-scipy 1.16.0_0+accelerate+gfortran
py313-scipy 1.16.2_1+acc 3.13.7_0lerate+gfortran
py313-tkinter 3.13.7_0
tk 8.6.16_0+x11
tk 20090316_0 8.6.17_0+x11
xorg 1.20.11_1 20090316_0 398_0
xorg-server 402_0.20.11_1
xterm 398_0
xterm 402_0
port select —summary:Name Selected Options
clang none mp-clang-19 none
fonttools fonttools-313 fonttools-311 fonttools-312 fonttools-313 none
gcc mp-gcc13 mp-gcc13 none
llvm none mp-llvm-19 mp-llvm-21 none
mypy none mypy311 mypy312 mypy313 none
pip none pip3-apple pip311 pip312 none
pip2 none none
pip3 none pip3-apple pip311 pip312 none
python python313 python311 python312 python313 none
python3 python313 python311 python312 python313 none
wxWidgets none wxWidgets-3.0 wxWidgets-3.2 none
port installe | grep -w tk: tk8.6.16_0+x11
tk 8.6.17_0+x11 (active)
tk-quartz 8.6.16_0
tk-quartz 8.6.17_0 (active)
tk-x11 8.6.16_0
tk-x11 8.6.17_0 (active)
echo $DISPLAY: :0.0
