Dear FLUKA expert, I compiled and installed the Flair geoviewer3.4-5.2.tgz using source on the CentOS 7 system. The Python version is 3.13. The following error occurred:
g++: fatal error: no input files
compilation terminated.
make: *** [geometryobject.o] Error 1
make: *** [geoviewer.o] Error 1
make: *** [gmesh.o] Error 1
make: *** [gobject.o] Error 1
make: *** [pyutils.o] Error 1
make: *** [viewerobject.o] Error 1
After manually compiling and generating these xxxx. o files, I executed the commands “make” and “make install DESTDIR=my_flair_path”. Flair can be opened normally, but once I click on the Geometry option, Flair immediately crashes. I don’t know how to solve this problem anymore, and I hope the experts can provide help. Thank you very much.
This is the complete command for me to install Flair Geoviewer:
tar -zxvf flair-geoviewer-3.4-5.2.tgz
cd flair-geoviewer-3.4
make
It will display:
Due to the display error indicating that the file ‘geometriobject. o’ does not exist, I used the following command to compile and generate the geometriobject. o file separately:
g++ -I/public/home/cuiyx/miniconda3/include/python3.13
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/data
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/farm
-I//public/home/cuiyx/Flair/flair-geoviewer-3.4/geometry
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/gldraw
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/graph
-I//public/home/cuiyx/Flair/flair-geoviewer-3.4/math
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/physics
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/tool
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/viewer
-I/public/home/cuiyx/Flair/flair-geoviewer-3.4/xdraw
-std=c++17
-fPIC -c geometryobject.cc -o geometryobject.o
Then I continue to use the ‘make’ command for compilation, and it will continue to report errors
I used the above method to compile all the missing *****. o files separately, and finally completed the compilation and installation of Flair Geoviewer using the make command without any problems. However, when I ran Flair and clicked on the geometry option, Flair crashed and exited.
I am using the version g++9.5.
This is an upgrade installation, and there were no issues with the previous version installation.
From the error message, it appears that the above command is missing the input file for the “*******. cc” file.
I manually modified this command: g++ -c -m64 -g -DUNIX -std=c++17 -O3 -DNDEBUG -D_DEBUG=0 -DTHREAD -pedantic -W -Wall -Wcast-qual -Wextra -Wformat -Wpointer-arith -Wshadow -Wno-write-strings -Wcast-align -Wredundant-decls -Wno-long-long -Wno-non-virtual-dtor -Wno-variadic-macros -Woverloaded-virtual -Wpointer-arith -Wshadow -Wunused -Wuninitialized -Wwrite-strings -Wshadow -pthread -Wno-class-memaccess -Wno-vla -fpic -fno-strict-aliasing -I. -I.. -I -I/public/home/cuiyx/python3.12/include/python3.12 -I/public/home/cuiyx/python3.12/include/python3.12 geometryobject.cc
I manually generated the “********. o” file corresponding to the “*******. cc” file. The compilation can continue, and the command ‘make install DESTDIR=my_flair_path’ was successfully executed. But after running Flair, it still shows that the Geometry module is not installed.
Can you try the following
go to the directory of geoviewer, there should be a geoviewer.so file generated from the makefile
Open python and type
$ python
Python 3.13.7 (main, Nov 24 2025, 20:51:28) [GCC 15.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import geoviewer
If you see any errors appearing after import it might reveal any error in the compilation
I solved this problem by manually compiling, and the Geometry module can now work properly. From the final issue, the reason for the inability to work is the lack of tk and tcl. Although I have set the paths for tk and tcl in the environment variables, the compilation cannot be done automatically and I still need to manually complete the remaining compilation.
