Good morning,
Where can I find the Flair-geoviewer installation instructions for Mac?
Thanks in advance,
Paolo
Good morning,
Thanks in advance,
Paolo
Sorry, I meant Flair-geoviewer installation instructions.
Paolo
Hi Paolo,
I assume that you have installed the Xcode command line tools which will provide you with GCC or CLANG. If not you can find the instructions under the link that Mihaela provided. Then I would suggest that you download the source code for geoviewer and compile it from scratch. The resulting file geoviewer.so then just needs to be put into the same directory where you have installed flair.
(see the instructions under the section “Compile from source” on the download page of FLAIR).
Hope that helps
Chris
