Dear Fluka experts,
Recently i am install latest flair in my ubuntu 22.04 system using " Only once instructions" ,following the procedure as (1) Install the public key (2)Install the repository.(3)Type the command. The flair seems installed successfully when the flair shows on my computer when i type flair command,.
However, the error message remind me there still some hindden error,as the attatched picture shows
Do you know why this error occur and how can i fix it?
Thanks you so much for your help,
Richard Lee
Thank you @liweiguang for the bug report.
Indeed the variable “flair” become local now and it was not accessible in this check_fluka routine.
To temporarily correct the problem open the flair.ini file from
${HOME}/.config/flair/flair.ini
and add a section
[Fluka]
directory = {path-to-fluka}
where {path-to-fluka} is the full path in your system where you have fluka installed
The bug is fixed and we will upload the correction on the web site in a while
