FLUKA: fluka4-5.1
Flair: flair-3.4
Operating system: Linux Ubuntu 18.04.6 LTS
Compiler: gfortran
While running the following command
make install install-bin install-mime
We got the errors as described below:
make -C viewer
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/viewer’
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/viewer’
make -C farm
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/farm’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/farm’
make -C geometry
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/geometry’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/geometry’
make -C data
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/data’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/data’
make -C graph
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/graph’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/graph’
make -C math
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/math’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/math’
make -C tool
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/tool’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/tool’
make -C xdraw
make[1]: Entering directory ‘/home/grb-216/flair-geoviewer-3.4/xdraw’
make[1]: Leaving directory ‘/home/grb-216/flair-geoviewer-3.4/xdraw’
mkdir -p /usr/local/flair
mkdir -p /usr/local/flair/fonts
test UNIX = UNIX && install -m 744 geoviewer.so /usr/local/flair || install -m 644 geoviewer.so /usr/local/flair
install: cannot remove ‘/usr/local/flair/geoviewer.so’: Permission denied
makefile:333: recipe for target ‘install’ failed
make: *** [install] Error 1
FLAIR geoviewer is not installed. Please suggest
