I think my installation is working file. The version of Flair is 3.1-8 [35316717 ]
My OS ver is RHEL 8.2 / kernel: 4.18.0-193.1.2.el8_2.x86_64
This will be our production server.
drop down menu ==> Dicom page indicates errors
Error: No module named ‘dicom’
pydicom library cannot be loaded
either pydicom is missing or some dependency is missing
Install: all # python -m pip install pydicom
Extra requirments (name depends on distributions):
python3-numeric, python3-imaging or python3-pillow,
python3-imaging-tk or python3-pillow-tk or python3-pil.imagetk
Following are my pkg/rpm status with the current OS build:
rpm -qa | grep python3 | grep dicom
python3-pydicom-1.4.2-2.fc32.noarch
the dicom package only required for processing medical DICOM files. Other flair features don’t require it.
It can be easily installed with
pip3 install -U pydicom
or, you maybe find it in your distributions repository.
In your case you installed a pydicom package from a Fedora 32 repository which is not compatible with your system. You will need to remove it first. (Similarly, the pillow packages from Fedora should be removed as well)
My RPP for PyDicom was from EPEL/Fedora upstream … Redhat doesn’t have a pkg for pydicom:
RPM info:
rpm -qa | grep python3 | grep -i pydicom
