Flair on macOS Sequoia 15.2
Greetings! I need help installing Flair please. This is not an OS upgrade. It is a brand-new baby. I made with
make -j 16 DEBUG=yes. Thanks!
 % PYTHON=/opt/local/bin/python3 ./flair
./flair: line 18: 76335 Bus error: 10           ${PYTHON} -O -W ignore ${DIR}/flair.py "$@"
 % port echo requested
gcc14                          @14.2.0_3+stdlib_flag
pkgconfig                      @0.29.2_0
py313-matplotlib               @3.10.0_0+tkinter
tk                             @8.6.16_0+x11
xorg                           @20090316_0
xorg-server                    @1.20.11_1
 % port select --summary
Name       Selected   Options
cython     none       cython313 none
fonttools  none       fonttools-313 none
gcc        mp-gcc14   mp-gcc14 none
llvm       none       mp-llvm-19 none
pygments   none       py312-pygments none
python     none       python310 python312 python313 none
python3    python313  python310 python312 python313 none
 % xcode-select --install
xcode-select: note: Command line tools are already installed. Use "Software Update" in System Settings or the softwareupdate command line interface to install updates
 % diff flair-geoviewer-3.3/geoviewer.so flair-3.3/geoviewer.so | wc -l
       0
 % c++ -v
Apple clang version 16.0.0 (clang-1600.0.26.6)
Target: arm64-apple-darwin24.2.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
 % pkgutil --pkg-info=com.apple.pkg.CLTools_Executables
package-id: com.apple.pkg.CLTools_Executables
version: 16.2.0.0.1.1733547573
volume: /
install-time: 1737079352
 % which g++ gcc gfortran ar
/opt/local/bin/g++
/opt/local/bin/gcc
/opt/local/bin/gfortran
/usr/bin/ar
# are we convinced that homebrew is not the culprit here
 % brew help
zsh: command not found: brew
Hello @mchin ,
I hope that you’re doing well!
I noticed that the installation with Python 3.13 is buggy.
Can you try with Python 3.12?
Cheers, Luigi
Hello @luillo,
Yes, I’m well. I hope you too! Your solution works of course, and gratefully appreciated as always. I took python3 back one step at a time. python312 didn’t work but python311 did. I now have Flair on my Sequoia in full glory.
Cheers!
mary
Hello @mchin ,
Glad that it works.
It’s strange that it does not work with Python 3.12.
Could you possibly post the full list of ports you have installed with the command port echo installed?
This could help to find the culprit in the MacPort installation.
Thanks.
Cheers, Luigi
Hi @luillo,
Sorry missed this earlier. Hope this isn’t too late.
Cheers @luillo!
% port echo installed
Warning: port definitions are more than two weeks old, consider updating them by running 'port selfupdate'.
appres                         @1.0.5_0
bdftopcf                       @1.1_0
bitmap                         @1.0.9_0
brotli                         @1.1.0_0
bzip2                          @1.0.8_0
cctools                        @949.0.1_3+xcode
curl                           @8.11.1_0+brotli+http2+idn+psl+ssl+zstd
curl-ca-bundle                 @8.11.1_0
db48                           @4.8.30_5
editres                        @1.0.7_0
expat                          @2.6.4_0
font-adobe-75dpi               @1.0.3_1
font-adobe-100dpi              @1.0.3_1
font-adobe-utopia-75dpi        @1.0.4_1
font-adobe-utopia-100dpi       @1.0.4_1
font-adobe-utopia-type1        @1.0.4_1
font-alias                     @1.0.4_0
font-arabic-misc               @1.0.3_1
font-bh-75dpi                  @1.0.3_1
font-bh-100dpi                 @1.0.3_1
font-bh-lucidatypewriter-75dpi @1.0.3_1
font-bh-lucidatypewriter-100dpi @1.0.3_1
font-bh-ttf                    @1.0.3_1
font-bh-type1                  @1.0.3_1
font-bitstream-75dpi           @1.0.3_1
font-bitstream-100dpi          @1.0.3_1
font-bitstream-speedo          @1.0.2_1
font-bitstream-type1           @1.0.3_1
font-cronyx-cyrillic           @1.0.3_1
font-cursor-misc               @1.0.3_1
font-daewoo-misc               @1.0.3_1
font-dec-misc                  @1.0.3_1
font-ibm-type1                 @1.0.3_1
font-isas-misc                 @1.0.3_1
font-jis-misc                  @1.0.3_1
font-micro-misc                @1.0.3_1
font-misc-cyrillic             @1.0.3_1
font-misc-ethiopic             @1.0.4_0
font-misc-meltho               @1.0.3_1
font-misc-misc                 @1.1.2_1
font-mutt-misc                 @1.0.3_1
font-schumacher-misc           @1.1.2_1
font-screen-cyrillic           @1.0.4_1
font-sony-misc                 @1.0.3_1
font-sun-misc                  @1.0.3_1
font-winitzki-cyrillic         @1.0.3_1
font-xfree86-type1             @1.0.4_1
fontconfig                     @2.15.0_0
fonttools_select               @0.1_1
fonttosfnt                     @1.2.2_0
freetype                       @2.13.3_0
fslsfonts                      @1.0.5_0
fstobdf                        @1.0.6_0
gcc14-libcxx                   @14.2.0_3+clang18
gcc_select                     @0.1_10
gdbm                           @1.24_0
gettext                        @0.22.5_0
gettext-runtime                @0.22.5_0
gettext-tools-libs             @0.22.5_0
giflib                         @4.2.3_1
git                            @2.48.0_0+credential_osxkeychain+diff_highlight+doc+pcre+perl5_34
git-tools                      @2022.12_0
glxgears                       @9.0.0_0
glxinfo                        @8.5.0_0
gmp                            @6.3.0_0
iceauth                        @1.0.8_0
ico                            @1.0.5_0
icu                            @76.1_0
isl                            @0.24_1
jbigkit                        @2.1_0
kerberos5                      @1.21.3_0
lcms2                          @2.16_0
ld64                           @3_6+ld64_xcode
ld64-xcode                     @2_6
lerc                           @4.0.0_1
libcomerr                      @1.47.1_0
libcxx                         @5.0.1_5
libdeflate                     @1.22_0
libedit                        @20240808-3.1_0
libffi                         @3.4.6_1
libgcc                         @9.0_0
libgcc14                       @14.2.0_3+stdlib_flag
libiconv                       @1.17_0
libidn2                        @2.3.7_0
libjpeg-turbo                  @3.1.0_0
libmpc                         @1.3.1_0
libpixman                      @0.44.2_0
libpng                         @1.6.44_0
libpsl                         @0.21.5-20240306_0
libtextstyle                   @0.22.5_0
libunistring                   @1.3_0
libxml2                        @2.13.5_2
libxslt                        @1.1.42_0
listres                        @1.0.4_0
llvm-19                        @19.1.7_0
llvm_select                    @2_1
lmdb                           @0.9.33_0
luit                           @2.0.20240102_0
lz4                            @1.10.0_0
mesa                           @24.3.2_0+llvm
mkfontscale                    @1.2.3_0
mpfr                           @4.2.1_0
ncurses                        @6.5_0
nghttp2                        @1.64.0_0
oclock                         @1.0.4_0
openjpeg                       @2.5.2_0
openssl                        @3_21
openssl3                       @3.4.0_1
p5.34-authen-sasl              @2.170.0_0
p5.34-cgi                      @4.670.0_0
p5.34-clone                    @0.470.0_0
p5.34-compress-raw-bzip2       @2.213.0_0
p5.34-compress-raw-zlib        @2.213.0_0
p5.34-digest-hmac              @1.50.0_0
p5.34-digest-sha1              @2.130.0_4
p5.34-encode                   @3.210.0_0
p5.34-encode-locale            @1.50.0_0
p5.34-error                    @0.170.290_0
p5.34-gssapi                   @0.280.0_3
p5.34-html-parser              @3.830.0_0
p5.34-html-tagset              @3.240.0_0
p5.34-http-date                @6.60.0_0
p5.34-http-message             @7.0.0_0
p5.34-io-compress              @2.213.0_0
p5.34-io-html                  @1.4.0_0
p5.34-io-socket-ssl            @2.89.0_0
p5.34-lwp-mediatypes           @6.40.0_0
p5.34-mime-base32              @1.303.0_0
p5.34-mime-base64              @3.160.0_0
p5.34-net-smtp-ssl             @1.40.0_0
p5.34-net-ssleay               @1.940.0_2
p5.34-regexp-ipv6              @0.30.0_0
p5.34-scalar-list-utils        @1.680.0_0
p5.34-term-readkey             @2.380.0_0
p5.34-time-local               @1.350.0_0
p5.34-timedate                 @2.330.0_0
p5.34-uri                      @5.310.0_0
pcre2                          @10.44_0
perl5.34                       @5.34.3_1
pkgconfig                      @0.29.2_0
popt                           @1.18_1
py311-brotli                   @1.1.0_0
py311-contourpy                @1.3.1_0
py311-cycler                   @0.12.1_0
py311-dateutil                 @2.9.0.post0_0
py311-fonttools                @4.55.3_0+lxml+unicode+woff
py311-kiwisolver               @1.4.8_0
py311-lxml                     @5.3.0_0
py311-matplotlib               @3.10.0_0+tkinter
py311-numpy                    @1.26.4_3+accelerate+gfortran
py311-oldest-supported-numpy   @0.1_0
py311-olefile                  @0.47_0
py311-packaging                @24.2_0
py311-pandas                   @2.2.3_0
py311-parsing                  @3.2.1_0
py311-Pillow                   @9.5.0_1
py311-pytzdata                 @2020.1_0
py311-six                      @1.17.0_0
py311-tkinter                  @3.11.11_0
py311-tqdm                     @4.67.1_0
py311-tz                       @2024.2_0
py311-unicodedata2             @16.0.0_0
py311-zopfli                   @0.2.3.post1_0
python3_select                 @0.1_0
python3_select-311             @0.1_1
python311                      @3.11.11_0+lto+optimizations
python_select                  @0.3_10
python_select-311              @0.3_1
qhull                          @2020.2_1
quartz-wm                      @1.3.2_1
readline                       @8.2.013_0
rendercheck                    @1.5_1
rgb                            @1.0.6_1
rsync                          @3.3.0_0
sessreg                        @1.1.2_0
setxkbmap                      @1.3.2_0
showfont                       @1.0.5_0
smproxy                        @1.0.6_0
sqlite3                        @3.48.0_0
tcl                            @8.6.16_0+corefoundation+threads
tiff                           @4.7.0_0
tk                             @8.6.16_0+x11
tk-quartz                      @8.6.16_0
tk-x11                         @8.6.16_0
transset                       @1.0.2_0
twm                            @1.0.10_0
viewres                        @1.0.7_0
webp                           @1.5.0_0
x11perf                        @1.6.1_0
xar                            @1.8.0.501_0
xauth                          @1.1.3_0
xbacklight                     @1.2.3_0
xbitmaps                       @1.1.2_0
xcalc                          @1.1.0_0
xclipboard                     @1.1.3_0
xclock                         @1.0.9_0
xcmsdb                         @1.0.5_0
xcompmgr                       @1.1.8_0
xconsole                       @1.0.7_0
xcursorgen                     @1.0.7_0
xditview                       @1.0.5_0
xdm                            @1.1.12_0
xdpyinfo                       @1.3.2_0
xedit                          @1.2.2_0
xev                            @1.2.4_0
xeyes                          @1.3.0_0
xfd                            @1.1.3_0
xfindproxy                     @1.0.4_1
xfontsel                       @1.0.6_0
xfs                            @1.2.0_1
xfsinfo                        @1.0.6_0
Xft2                           @2.3.8_0
xgamma                         @1.0.6_0
xgc                            @1.0.5_0
xhost                          @1.0.8_0
xinit                          @1.4.1_1
xinput                         @1.6.3_0
xkbcomp                        @1.4.5_0
xkbevd                         @1.1.4_0
xkbprint                       @1.0.5_0
xkbutils                       @1.0.4_1
xkeyboard-config               @2.5.1_1
xkill                          @1.0.5_0
xload                          @1.1.3_0
xlogo                          @1.0.5_0
xlsatoms                       @1.1.3_0
xlsclients                     @1.1.5_0
xlsfonts                       @1.0.6_0
xmag                           @1.0.6_0
xman                           @1.1.5_0
xmessage                       @1.0.5_0
xmh                            @1.0.3_0
xmodmap                        @1.0.10_0
xmore                          @1.0.3_0
xorg                           @20090316_0
xorg-apps                      @20151011_0
xorg-encodings                 @1.0.5_1
xorg-fonts                     @20090102_1
xorg-libAppleWM                @1.4.1_1
xorg-libdmx                    @1.1.5_0
xorg-libfontenc                @1.1.8_0
xorg-libFS                     @1.0.10_0
xorg-libice                    @1.1.1_0
xorg-libpthread-stubs          @0.5_0
xorg-libsm                     @1.2.4_0
xorg-libX11                    @1.8.10_0
xorg-libXau                    @1.0.11_0
xorg-libXaw                    @1.0.16_1
xorg-libxcb                    @1.17.0_0+python313
xorg-libXcomposite             @0.4.6_0
xorg-libXcursor                @1.2.3_0
xorg-libXdamage                @1.1.6_0
xorg-libXdmcp                  @1.1.5_0
xorg-libXext                   @1.3.6_0
xorg-libXfixes                 @6.0.1_0
xorg-libXfont                  @1.5.4_2
xorg-libXfont2                 @2.0.7_0
xorg-libXfontcache             @1.0.5_2
xorg-libXi                     @1.8.2_0
xorg-libXinerama               @1.1.5_0
xorg-libxkbfile                @1.1.3_0
xorg-libXmu                    @1.2.1_0
xorg-libXp                     @1.0.4_0
xorg-libXrandr                 @1.5.4_0
xorg-libXScrnSaver             @1.2.4_0
xorg-libXt                     @1.3.1_0+docs
xorg-libXTrap                  @1.0.1_1
xorg-libXtst                   @1.2.5_0
xorg-libXv                     @1.0.12_0
xorg-libXxf86vm                @1.1.5_0
xorg-scripts                   @1.0.1_0
xorg-xcb-proto                 @1.17.0_0+python313
xorg-xcb-util                  @0.4.1_0
xorg-xorgproto                 @2024.1_0
xpm                            @3.5.17_0
xpr                            @1.0.5_0
xprop                          @1.2.5_0
xrandr                         @1.5.2_0
xrdb                           @1.2.1_0
xrefresh                       @1.0.6_0
xrender                        @0.9.11_0
xset                           @1.2.4_1
xsetmode                       @1.0.0_1
xsetpointer                    @1.0.1_1
xsetroot                       @1.1.2_0
xsm                            @1.0.4_0
xstdcmap                       @1.0.4_0
xterm                          @388_0
xtrap                          @1.0.3_0
xvinfo                         @1.1.4_0
xwd                            @1.0.8_0
xwininfo                       @1.1.5_0
xwud                           @1.0.5_0
xxhashlib                      @0.8.3_3
xz                             @5.6.3_0
zlib                           @1.3.1_0
zstd                           @1.5.6_0
Hello @mchin ,
After contacting MacPorts support, we have a solution for Python 3.13 (or Python3.12 as well for you).
You can test it with the following instructions:
sudo port install tk +x11 # not needed in your case
Then rebuild py313-tkinter from source
sudo port -ns upgrade --force py313-tkinter
Or, if you haven’t installed the port yet, use:
sudo port -ns install py313-tkinter
Before testing, remember to select the proper Python version :slight_smile:
sudo port select --set python3 python313
Let me know if this works for you as well.
Cheers, Luigi
Hello @luillo,
This works perfectly!
Cheers!
mary
