Flair segmentation fault on MacOS
Dear all,
The same problem occurs when running Flair 3.1 on macOS Catalina and Python version 3.8.3, and I don’t know how to fix it.
fluka/flair-3.1/flair: line 14: 2355 Segmentation fault: 11 ${PYTHON} -O -W ignore ${DIR}/flair.py "$@"
Maybe, but I think it would be quite strange since macOS goes to swap when needs more RAM and I’ve never had a RAM problem even in running ML algorithms.
Regards
Dear @pperez,
Could you please provide the output of the following commands?
port echo requested
flair -h | grep Version
Thanks,
Thanos
Dear @manousos,
Here the output of the commands,
% port echo requested
gcc8                           @8.4.0_1
gcc9                           @9.3.0_2
gcc10                          @10.2.0_1
ghostscript                    @9.52_0+x11
gnuplot                        @5.2.8_0+aquaterm+luaterm+pangocairo+wxwidgets+x11
ld64                           @3_3+ld64_xcode
pkgconfig                      @0.29.2_0
py38-matplotlib                @3.3.0_1+tkinter+webagg
py38-numpy                     @1.19.2_0+gfortran+openblas
py38-Pillow                    @7.2.0_1+x11
py38-pip                       @20.2.3_0
py38-pydicom                   @2.0.0_0
py38-scipy                     @1.5.2_0+gfortran+openblas
py38-tkinter                   @3.8.6_0
sqlite3-tcl                    @3.33.0_0
xorg                           @20090316_0
xorg-server                    @1.20.9_0
% flair -h | grep Version
 Version:	3.1-4 [7cd4db4d ]
Thanks,
Pedro.
Fixed!
I don’t know why, but re-installing all for gcc8 this time.
Thank you very much1
