Dear Fluka experts,
I am trying to simulate energy deposition by using flair and shell script. But whenever i tried to simulate MUON+, the error file(“fluka_somenumber”, it contains “core” file) shown up and as my understanding it is originated from flair which does not recognise MUON+ as a particle type.
Also, " Invalid operator at the beginning/end of a subexpression, execution termina
ted ***
MUON+
Abort called from EXPREV reason INVALID OPERATOR IN SUB-EXPR! Run stopped!
STOP INVALID OPERATOR IN SUB-EXPR!" is written in the .log and .err file.
Even i wrote it with quotation marks( and double quotation marks, i tried many versions) in the script file. When i use quotation mark, the error file does not exist but the program is not processing(running) anyway. There must be a fort_ file to process the calculated data but it is not exist. The problem is on only MUON+ because for other particles the script file is working good and the results are consistent with the previous simulation datas which is made by hand, not by a script file.
I will be waiting for your helps. Thank you in advance.
Sevgi ILGAR
