Dear colleagues,
I am running a FLUKA simulation with a custom executable, and I get the error reported below.
I am running the latest FLUKA version (4.3.3) on a Centos7 machine, gcc9.2.0. I also tried to run without the custom executable, just running the command:
$FLUPRO/bin/rfluka -N0 -M1 na64_2021.inp
and I get the same error. The input card is attached to this message.
na64_2021.inp (358.9 KB)
May I ask you where this error originates from?
Thanks,
Andrea
Error:
At line 681 of file cascade/synstp.f
Fortran runtime error: Index '0' of dimension 1 of array 'cmpemf' below lower bound of 1
Error termination. Backtrace:
#0 0x673eab in synstp_
at cascade/synstp.f:681
#1 0x66c7e6 in magnew_
at cascade/magnew.f:1767
#2 0x628fcf in kaskad_
at cascade/kaskad.f:3499
#3 0x4ea6d0 in feeder_
at cascade/feeder.f:277
#4 0x45a170 in flukam_
at main/flukam.f:2796
#5 0x43b450 in fluka
at main/fluka.f:77
#6 0x43b450 in main
at /shared/src/usflmd.inc:15
Follow-up
From an intuition suggested by the name of the file synstp.f, I modified my input card to switch off the syncrotron radiation emission (SYRASTEP card). The error is no longer present, but I can’t tell if this is due simply to the fact that, disabling this card, the history of the simulation changes, and maybe another, totally unrelated case that triggered the error simply did not occur…
