I am running Ubuntu 18.04 LTS (64-bit). When following the FLUKA installation instructions for (.deb) and software requirements I encounter an error during installation as super user. I am using the advised FLUKA fluka-2011-3.0.Linux-gfor9_amd64.deb version. Gfortran 8.3 installed.
The libc6 is only available in version 2.27 on the Ubuntu standard repo via apt install. However, FLUKA requires libc6 version 2.29 or higher.
I found an online repo for the 2.29 version via .deb download (alternative to compiling from libc6 source).
http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/
Example:
http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/libc6_2.30-0ubuntu3_amd64.deb
However, trying to install libc6 higher than 2.27 breaks locales. Now I am not sure how smart it is to force a full libc6 replace including locales.
Is there a known, better fix for this i.e. installing a different FLUKA package? Is FLUKA currently really in need of libc6 2.29 or would 2.27 be sufficient?
Thanks for your help!
Error message:
sudo dpkg -i fluka-2011-3.0.Linux-gfor9_amd64.deb
[sudo] password for username:
Selecting previously unselected package fluka.
(Reading database … 83593 files and directories currently installed.)
Preparing to unpack fluka-2011-3.0.Linux-gfor9_amd64.deb …
Unpacking fluka (2011-3.0) …
dpkg: dependency problems prevent configuration of fluka:
fluka depends on libc6 (>= 2.29); however:
Version of libc6:amd64 on system is 2.27-3ubuntu1.
dpkg: error processing package fluka (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
fluka
