[From: Input workspace is blank]
Yes, I loaded the basic template. I tried re-installing Fluka and Flair. The pop up message now appears and the input tab is no longer blank. However, I now get two errors when I try to plot and run the results from the tutorial. I am assuming it is user error, and will try to work through the tutorial again to make sure I inputed all the values correctly.
Started 2020.09.06 11:35:45
gnuplot> reset
gnuplot> set terminal aqua 0 enhanced solid title 'trial-0: ’
gnuplot> set title ‘’
gnuplot> unset grid
gnuplot> set xlabel ‘’
gnuplot> set xtics
gnuplot> set ylabel ‘’
gnuplot> set ytics
gnuplot> unset logscale x
gnuplot> unset logscale y
gnuplot> unset logscale z
gnuplot> unset logscale cb
gnuplot> unset logscale x2
gnuplot> unset logscale y2
gnuplot> set key default
gnuplot> plotname=‘Red’
Cmd: /Users/thomascarstens/fluka4-0.1/bin/rfluka -M 1 /Users/thomascarstens/flair__pyq6_wh
F L U K A
Dir: /Users/thomascarstens/fluka4-0.1
Data: /Users/thomascarstens/fluka4-0.1/data
Exec: /Users/thomascarstens/fluka4-0.1/bin/fluka
Input: /Users/thomascarstens/flair__pyq6_wh.inp
Initial seed copied from /Users/thomascarstens/fluka4-0.1/data
Running fluka in /Users/thomascarstens/fluka_1236
Error: “/Users/thomascarstens/fluka4-0.1/bin/fluka” executable returned RC=2
… fluka run: 1.29772 s
e> ERROR: Return Code=2
Started 2020.09.06 11:37:51
- Running: trial
Cmd: /usr/bin/nohup /Users/thomascarstens/fluka4-0.1/bin/rfluka -M 5 trial
F L U K A
Input: /Users/thomascarstens/trial.inp
Running fluka in /Users/thomascarstens/fluka_1314
Error code: 12
Thank you.
