I was installing the new version of FLUKA, FLUKA4.0, on my Mac, following the instruction Installing FLUKA on GNU/Linux or macOS. However, when I type make command in the src directory, the terminal returns the following error:
gfortran -o /Users/z/FLUKA/fluka4-0.0//bin/fluka -L/Users/z/FLUKA/fluka4-0.0//lib -lfluka
ld: can’t open output file for writing ‘/Users/z/FLUKA/fluka4-0.0//bin/fluka.ld_dF9mfO’, errno=13 for architecture x86_64
make: *** [/Users/z/FLUKA/fluka4-0.0//bin/fluka] Error 1
Hi @Ephemera,
the setup seems ok.
Your message suggests that you have permission issues on the destination folder /Users/z/FLUKA/fluka4-0.0
Could you check the permissions of this folder and of the files inside?
For example, can you create a file inside with the following command? touch /Users/z/FLUKA/fluka4-0.0/x
Hi, Luigi
Thank you! I used sudo make, and it worked for fluka4-0.0.
However, when I’m following the flair installation instruction (https://flair.web.cern.ch/flair/download.html), having successfully installed flair3.1, the flair-geoviewer-3.1 compilation failed.
Compile
To compile flair-geoviewer do the following:
$ tar xzvf flair-geoviewer-X-XX.tgz $ cd flair-geoviewer-X-XX $ make -j 8 $ make install DESTDIR=PATH_FLAIR
and replace PATH_FLAIR with the directory path where Flair was expanded.
Compile in parallel: -j 8 replace with the number of cores you have available
The first three steps were alright, but the forth step $ sudo make install DESTDIR=/Users/z/FLUKA/flair-3.1/, it gives the following error message.
Hi @Ephemera,
I understand that you have solved the problem of the FLUKA installation.
From the last snapshot, it’s not clear if you still have problems with Flair/geoviewer.
Of course, let us know in case you need further assistance.
I would also add that you need the sudo command only to install MacPorts ports, but
I recommend not to use it to compile FLUKA/Flair/geoviewer
Cheers, luigi
Hi, Luigi
Sorry I didn’t express myself clearly in the last post.
I still have a problem installing geoviewer. When I type in the command make install DESTDIR=/Users/z/FLUKA/flair-3.1/, the terminal returns the following error:
Dear @Ephemera,
the instructions to install Flair/Geoviewer are in the Flair page
In your previous message I see that you had a different setup based on python37.
Here the error mentions python36… Moreover, the error suggests that you are not using the MacPorts python.
What is the output of these commands? echo $PATH which python3
