Respected FLUKA expert,
Fluorinated Polymer is A kind of optical fiber’s cladding material,it is not within the list of pre-defined ICRU compound,could I use something else to instead it?
xiongbp
Dear Xiong,
please have a look on this lecture explaining how you can create your own materials in FLUKA:
I have understand ,thank you David
Test.inp (3.2 KB)
Respected FLUKA expert:
The attachment is my file.When I run the file,it occurs “Finished with errors” a few moments later,while the “example.inp” runs normally.Could you help me solve the problem? Thank you!
Dear Xiong,
most of your COMPOUD cards are incomplete. You always need to specify the ratio between the elements.
Oh, I am sorry I forget,
Thank you Dear David
