Focus user routine
Dear experts
I am working with the FOCUS routine, that routine is old and it used the script ldpm3qmd which now is not in Fluka, I replace it with a new one ldpmqmd, the problem is: The simulation is running but It is not producing the executable file.
I have attached one screenshot.
Hallo, in fact the simulation does not seem to even start, since the executable is not found. Can you share your script?
Dear Francesco, thanks a lot for answering.
I have attached the routine as a zip file.
You have to change some address in the files:
In the execute.py line 50 you should put the right address of your rfluka file, in my case was /bin instead of /flutil
In the compile.py line 49 you should put the right address of your fff file, n my case was /bin instead of /flutil and I had to change in the line 50 the file ldpm3qmd (which does not exist anymore) you should put the file ldpmqmd (without 3) and put the right address /bin → /flutil.
Cesar
Dear Cesar, in your resulting log_#_#.txt file you can see the problem:
Error: Can’t open included file ‘(DBLPRC)’
Go into focus_lib/routines, where your (obsolete) user routines sit, and type the command
your_FLUKA_path/bin/fluka_src_converter.py *.f
This way your simulation will successfully start … and fail due to an incomplete LOW-MAT card for your HYD_Obnd material in the input file.
Thanks Francesco for your help.
Yes, I complete the LOW-MAT in the .inp file but when I tried to run it I have an error … FLUKA-CERN/FlukaExamples/FOCUS/CMSexecute" executable returned RC=136
Look at the .log, .err and *001.out files.
