Hi everyone,
I stumbled upon a case where the transport card EMFCUT with the wrong FUDGEM value was running instead of crashing as the FUDGEM=0 should be a “not allowed condition” according to the last manual.
*...+....1....+....2....+....3....+....4....+....5....+....6....+....7....+.... EMFCUT -1E-06 1E-6 0 HYDROGEN @LASTMAT PROD-CUT
This issue is similar to https://fluka-forum.web.cern.ch/t/emf-cut-problems-about-what-3/847
but while Honghu had not default (and therefore an error) I had instead 0 (by mistake) and - as the simulation was running - I didn’t realize that until I had to change the transport and production energies.
My bad clearly. One should always check the physics setting before running.
In order to evaluate how is the effect of this on older simulations which I run - and save kW of CPU power to rerun the simulation - I would like to know (if possible) how is this FUDGEM=0 interpreted by the code.
Thank you in advance for you help!
Best
Vittorio
P.S. (edited) the notes in the manual have also an example where FUDGEM is set to 0
Example 1 (number-based):
EMFCUT -1.0E-5 1.0E-5 0.0 4.0 8.0 PROD-CUT
* A production threshold of 10 keV is set for electrons, positrons and
* photons in all materials from 4 to 8.
The same example, name-based:
EMFCUT -1.0E-5 1.0E-5 0.0 HELIUM OXYGEN PROD-CUT
