FLUKA:4.5.1
Flair:not used
When building geometry, all estimators worked fine when there are just three layers but gave all-zero results when I inserted the fourth layer.
(flat source at z=-50.0cm)
RPP world -500000000.0 +500000000.0 -500000000.0 +500000000.0 -5000000.0 +5000000.0
RPP void -100000000.0 +100000000.0 -100000000.0 +100000000.0 -1000000.0 +100000.0
RPP target -100000000.0 +100000000.0 -100000000.0 +100000000.0 -1000000.0 -100.0XYP surface 0.0
regBH1 5 +world -void
regVA2 5 +void -target
*regVA2 5 +void +surface
*regVA3 5 +void -surface -target
regTA3 5 +targetASSIGNMA,TARGET,regTA3
ASSIGNMA,BLCKHOLE,regBH1
ASSIGNMA,VACUUM,regVA2
*ASSIGNMA,VACUUM,regVA3
estimators are placed between TA3 and VA2 when there are only three layers and TA and VA3 when there are four. theoretically, I literally introduced zero change to the materials in my system, so no drastic change should occur, and back-scattering particles should be detected in both cases. Yet it only functioned in the three-layer case but not in the four-layer case.
It would be sincerely helpful to solve this problem since I need to raise the height of my estimator.
