I am running flair 3.0-9 and I have run into some annoying visualization issues in the geometry tab when a usrbin is overlayed;
When the colour contour overlaps with the coordinate system then it is no longer visible.
The usually drawn lines of the region interfaces are not visible when a pla or a cylinder or sphere (at least the ones I tested, maybe not an exhaustive list).
On a separate note.
When I am trying to select some bodies and I click “d” to create a new region and then try to select the region of interest, it does not work. If I do it for a second time (by pressing esc and then “d” again) then it works.
Attached you may find a sample flair and input file.
Thank you @e.skordis for the bug report
In the usrbinlayer.cc I had wrong parenthesis in a condition to ignore the boundary pixels.
Line 46 should be like if ((viewer.d3.show && flag!=FLAG_REGION) || flag&FLAG_ALPHA) continue;
while wrongly in the code the parenthesis are around (flag!=FLAG_REGION) || flag&FLAG_ALPHA)
I will push a new respin quite soon together with some other bug corrections. If in the mean time you want to correct the display problem, just replace the line as I mentioned above and recompile
I’ve fixed also the d problem. It was set in the new version to swap between actions while the dialog is on. However it was swapping also when the dialog was not visible, so you where getting the wrong action every second hit.
Just for future reference to anyone that updated to 3.0.10 in the meantime as I did:
Since it’s the same version you do not get the update automatically. You have to force re-installation of flair-geoviewer with;
sudo apt --reinstall install flair-geoviewer
