Hi, I’m updating Flare and Flare-Geoviewer to 3.0-12 in preparation for the upcoming course. Geoviewer compiles and installs without any obvious errors, but Flare then produces the following error:
>w> Warning: Geometry Viewer not found
>e> ERROR: dlopen(/Users/tgiles/bin/flair-3.0/geoviewer.so, 2): Symbol not found: _main
Referenced from: /Users/tgiles/bin/flair-3.0/geoviewer.so
Expected in: flat namespace
in /Users/tgiles/bin/flair-3.0/geoviewer.so
This is on MacOS Catalina with MacPorts, gcc9, python 3.8 and xorg, all as per online instructions.
Any help gratefully received! -Tim
The detailed installation was as follows:
xcode-select --install
sudo port -v selfupdate
sudo port upgrade outdated
sudo port install xorg-server xorg # NB logout and back in to activate xorg-server
sudo port install gcc9
sudo port select gcc mp-gcc9
sudo port install python38 # NB python version should be consistent among the following lines
sudo port select --set python3 python38
sudo port install py38-tkinter
sudo port install pkgconfig
sudo port install ghostscript
sudo port install gdb
sudo port install xterm
sudo port install gnuplot
sudo port install py38-Pillow
sudo port install py38-numpy
sudo port install py38-matplotlib +tkinter
sudo port install py38-scipy
sudo port install py38-pydicom
# install Flair
cd ~/system
wget https://flair.web.cern.ch/flair/download/flair-3.0-12.tgz
cd ~/tmp
tar -zxf ~/system/flair-3.0-12.tgz
mv ~/bin/flair-3.0{,.old}
mv flair-3.0 ~/bin/
# install Flair-Geoviewer
cd ~/system
wget https://flair.web.cern.ch/flair/download/flair-geoviewer-3.0-12.tgz
cd ~/tmp
tar xzvf ~/system/flair-geoviewer-3.0-12.tgz
cd flair-geoviewer-3.0
make -j 2
make install DESTDIR=$HOME/bin/flair-3.0
echo >>~/.bash_profile "alias flair='$HOME/bin/flair-3.0/flair'"
Hi all,
please allow me to revive this thread, as I find myself in a similar situation.
On MacOS Catalina and MacPorts (gcc9, gfortran9, python 3.8 and xorg), as described above, I encounter the same warning message but a different error message when I open flair.
e> ERROR: No module named ‘geoviewer’
All tabs in flair work, except for the Geometry tab.
I tried to follow switching to Python 3.7, as this was the solution here, but py37-numpy port fails. I copy below how:
sudo port install py37-numpy
—> Computing dependencies for py37-numpy
The following dependencies will be installed:
gcc10
py37-cython
py37-nose
Continue? [Y/n]: y
—> Fetching archive for gcc10
—> Attempting to fetch gcc10-10.1.0_0.darwin_19.x86_64.tbz2 from Index of /gcc10
—> Attempting to fetch gcc10-10.1.0_0.darwin_19.x86_64.tbz2.rmd160 from Index of /gcc10
Error: Failed to archivefetch gcc10: Failed to fetch signature for archive: The requested URL returned error: 504
Error: See /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_lang_gcc10/gcc10/main.log for details.
Error: Follow MacPorts Guide to report a bug.
Error: Processing of port py37-numpy failed
Could anybody provide some guidance on how to proceed?
Thank you in advance,
Vasiliki
Dear @vkousk,
I was eventually able to reproduce your issue.
This is not related to the python version.
We’ll keep you updated as soon as we release the solution.
Sorry for the inconvenience.
