Hi @manousos
I still get the same output for
which python3
After uninstalling and reinstalling xcode I get:
Jasons-MacBook-Pro-2:flair-geoviewer-3.1 J$ make install DESTDIR=/Users/J/Desktop/FLUKA/flair-3.1
/Library/Developer/CommandLineTools/usr/bin/make -C viewer
make[1]: Nothing to be done for `all’.
/Library/Developer/CommandLineTools/usr/bin/make -C geometry
/Library/Developer/CommandLineTools/usr/bin/make -C data
/Library/Developer/CommandLineTools/usr/bin/make -C graph
/Library/Developer/CommandLineTools/usr/bin/make -C math
/Library/Developer/CommandLineTools/usr/bin/make -C farm
/Library/Developer/CommandLineTools/usr/bin/make -C tool
/Library/Developer/CommandLineTools/usr/bin/make -C xdraw
c++ -o geoviewer.so geometryobject.o geoviewer.o gmesh.o gobject.o pyutils.o viewerobject.o -g -DDarwin -O3 -funroll-loops -DNDEBUG -D_DEBUG=0 -ftree-vectorize -DTHREAD -std=c++11 -pedantic -W -Wall -Wcast-align -Wcast-qual -Wextra -Wformat -Wpointer-arith -Wredundant-decls -Wshadow -Wno-write-strings -Wno-long-long -Wno-non-virtual-dtor -Wno-variadic-macros -Woverloaded-virtual -Wpointer-arith -Wshadow -Wunused -Wuninitialized -Wwrite-strings -Wshadow -pipe -pthread -Wno-class-memaccess -fwrapv -fstack-protector -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk -m64 -dynamiclib -L/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/config-3.8-darwin -ldl -framework CoreFoundation -L. -L/opt/local/lib -lX11 -Lviewer -lviewer -Lgeometry -lgeometry -Ldata -ldata -Lgraph -lgraph -Lmath -lmath -Lfarm -lfarm -Ltool -ltool -Lxdraw -lxdraw -lX11 -lpthread -lm -undefined dynamic_lookup
ld: unsupported tapi file type ‘!tapi-tbd’ in YAML file ‘/Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/System/Library/Frameworks//CoreFoundation.framework/CoreFoundation.tbd’ for architecture x86_64
make: *** [geoviewer.so] Error 1
Now when I try to open flair it crashes immediately. With the following sequence:
Jasons-MacBook-Pro-2:~ J$ /Users/J/Desktop/FLUKA/flair-3.1/flair ; exit;
w> Warning: PIL.Image and PIL.ImageTk not found
/Users/J/Desktop/FLUKA/flair-3.1/flair: line 14: 19342 Segmentation fault: 11 ${PYTHON} -O -W ignore ${DIR}/flair.py “$@”
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
Thank you,
-Jason
