Dear professors:
I’m using USDRAW in mgdraw.f to record the productions and reactions for isotopes. I notice that the heavy evaporation fragments are not included in USDRAW according to the manual. So I have written two ways to record in mgdraw.f. Take DEUTERON for example:
IF (KPART(IP) .EQ. -3 ) THEN WRITE(96,'(A15, I15, 3ES15.3,4I15)') "DEUproduce", ICODE, XSCO, YSCO, ZSCO, MREG, ICRES, IBRES, ISMRES WRITE(96,'(A15, I15)') "DEUparent", JTRACK WRITE(96,'(A15,4ES15.3)') "DEUTERON", CXR(IP)*PLR(IP), CYR(IP)*PLR(IP), CZR(IP)*PLR(IP), AGESEC(IP) WRITE(96,'(A15)') "DEUproend"
IF (KHEAVY(IP) .EQ. 3 ) THEN WRITE(96,'(A15, I15, 3ES15.3, 4I15)') "DEUevapo", ICODE, XSCO, YSCO, ZSCO, MREG, ICRES, IBRES, ISMRES WRITE(96,'(A15, I15)') "DEUevaparent", JTRACK WRITE(96,'(A15, 4ES15.3)') "evaDEUTERON", CXHEAV(IP)*PHEAVY(IP), CYHEAV(IP)*PHEAVY(IP), CZHEAV(IP)*PHEAVY(IP), AGHEAV(IP) WRITE(96,'(A15)') "DEUevaend"
I wonder if it can involve all the productions and avoid double counting at the same time in this way.
Because I have found the following lines in the result (I have omitted the irrelevant information):
DEUproduce 101 4.938E+01 3.449E+02 2.191E+03
DEUparent 9
DEUTERON 1.375E-01 -2.696E-01 -4.754E-01 0.000E+00
DEUproend
DEUevapo 101 4.938E+01 3.449E+02 2.191E+03
DEUevaparent 9
evaDEUTERON 2.748E-01 4.106E-02 -3.734E-02
DEUevaend
These “two” DEUTERON have the same position but different momentum. Can I interpret these lines as that one inelastic interaction occurs with one DEUTERON produced and another DEUTERON is evaporated after the residual nuclei is cooled, or it has simply only one DEUTERON? I have uploaded the files if needed. Thank you for your help!
Best
Hechong Han
muon.txt (151.6 KB)
Te-LS.inp (3.5 KB)
newsource.f (7.3 KB)
mgdraw.f (11.4 KB)
mdstck.f (3.0 KB)
