Dear FLUKA expert,
I want to benchmark this paper "**EVALUATION OF SKYSHINE FROM AN ACCELERATOR FACILITY:
DEPENDENCE ON DISTANCE AND ANGLE ". The FLUKA input is attached. but flair can’t plot the result. goal is obtaining Neutron flux in ring detectors around the room.
which change should be done in PLOT options?
benchmark.inp (11.6 KB)
best regards,
yashar
Dear @yashar86shahoo,
you shared your .inp file rather than your .flair therefore it is impossible to know which plots you are trying to make, therefore it is impossible to help you.
thank you,
I mean the .inp file.
I see two options here:
1-You have a problem with a specific plot you set up.
In this case you have to share the .flair file in order for other people to see what the problem could be.
2-You have not set up any plot yet.
In this case you should look at the material already available, namely:
- the Flair introduction lecture where plotting is discussed,
- the Scoring 1 lecture where scoring and plotting are discussed,
- the Scoring 2 where more scoring is discussed, and
- plenty of threads on the forum discussing plotting and its problem including empty plots.
