How do I add DataSet information to FLAIR
Hi @akimikko
on your previous thread
The problem of DCM format conversion in FLAIR I’ve mentioned to you that your conversion program had some issues. The main was that all images had the same origin.
You see that the Dimension Z component is 0.0
Unfortunately I don’t know matlab to help you on how to correct it there.
One option would be to write a program, either in matlab or in python to load one by one the slices and correct the Slice Location and the Image Position (Patitient)
that currently for each slice they point to -325 and 1295mm respectively.
Appart from that I don’t know what other problem it might have.
Vasilis
