The weights for each cycle and each spawn are printed in .out file. If there are 5 cycle and 10 spawns, there will be 50 .out files. Is there anyway to get the total weights in a single file or do we have to add it manually ?
you need to “grep” the files.
Keep in mind, that the weights of each cycles are automatically taken into account by the post-processing programs to produce the summary of the built-in scorings.
“grep” is a standard linux command that allows to search for strings within text files.
From command line you can just type:
man grep
to get a description (pasted below) and the basic info on how to use it.
DESCRIPTION
grep searches for PATTERN in each FILE. A FILE of “-” stands for standard
input. If no FILE is given, recursive searches examine the working directory, and
nonrecursive searches read standard input. By default, grep prints the matching
lines.
In addition, the variant programs egrep, fgrep and rgrep are the same as
grep -E, grep -F, and grep -r, respectively. These variants are deprecated, but
are provided for backward compatibility.
You can also just google “grep linux” to find plenty of pages on how to use it.
