How to check the [Compile] results?
Hey,
I wanna to build a cylinder source by user-defined editing source_newgan.f.
However, after following the tutorial as shown in the image to compile, I don’t know how to check the compilation results.
At this point, should the PLOT Source results reflect the new definitions made in source_newgen.f?"
My results is:
looking forward to reply.
Dear @CSH ,
you can find the the printout from the compilation on the [Output] tab, which you can access similarly to the [Compile] with the down arrow on top right.
Or, with the terminal icon, on the bottom right corner of Flair.
Alternatively, you can click the popup notification.
