I want to know how to define the proton intensity in FLUKA?
Dear @Junjie_Zhang,
Fluka results for prompt quantities are given per primary particle. The “beam intensity” can be represented as a normalization factor that you apply to your results.
E.g. if the result of whichever quantity you want to estimate is X, it means that 1 primary particles gives you x; if you have let say 10^{10} primaries per bunch, then the results for a bunch would be 10^{10} x.
Instead, if you interested in an activation problem, the beam intensity is relevant and needs to be specified in the IRRPROFI card. For the details, have a look at:
