How to know the run progress without flair
Dear Fluka experts,
I used the following command in the terminal to compile and run the Fluka program.
lfluka -m fluka -o myfluka mgdraw.f source_newgen.f
rfluka -e myfluka -N0 -M1 neutrino.inp
What I am simulating is the reaction of high-energy neutrinos, which is quite time-consuming. If I want to know the progress of the simulation,for example, which event is being simulated currently—what should I do?
I can currently compile and run the program successfully. Below is the program I used.
neutrinomu.inp (1.3 KB)
mgdraw.f (10.7 KB)
neutrinomu.flair (1.0 KB)
source_newgen.f (18.9 KB)
Dear Dawei,
you can follow the progress in the .err file, where FLUKA prints the information of the random number seed, started primaties, and the average time required by a single primary regularly.
By default the printout happens every total_primary * 0.02 events, but it is possible to request it after each primary via the START card. Please note, this will increase the size of the .err file significantly.
For more see: 7.22.76. START — FLUKA Manual
Thank you for your reply, it has cleared up my confusion.
Dawei
