I use source.f as user source, the code can be compiled, but when running the fluka application, the error occurs:
Error: “/home/llh/Fluka/Projection/Li6Chamber/source” executable returned RC=2
but with the array concerning the data in the file, everythings work ok.
and i write the fortran code similar for fluka of INFN version, it works well.
and it write a special fortran code to check out “reading the data from the file”, it works well.
the source.f code and the data file are uploaded, i rename the data file from STARGET_144KEV.ENE to STARGET_144KEV.txt for uploading.
it seems some special detail need to do, what is wrong with my fortran code?
STARGET_144KEV.txt (12.7 KB)
source.f (11.2 KB)
