How to use phase space in flair
I want to use FLAIR to implement functionality similar to GEANT4’s phase space, where the particle states in certain regions of the space from the first simulation are saved and imported into a subsequent simulation to save computational costs. How can I achieve this?
Hello @maoxin
I believe what you are looking for is the functionality of the source_newgen.f routine. You will need to compile an executable and properly use it in Flair, along with a file that lists the phase space variables you want to use.
I suggest to start with the source routine lecture from the last FLUKA beginners course. Please then have a look at this post on the use of the source_newgen.f routine to read the phase space file, or this post on how to verify the phase space file is read correctly.
Hope this helps,
Andreas
