Dear administrator,
Sorry to disturb you again, I have solved the above problems. I have encountered a new problem that I have seen the manual and the forum without finding a suitable solution. How can I read the electronic beam cross section information in a certain position in vacuum? I had uesd the card USRBIN and BEAMPART but I can’t get the distribution like the fig. I want to arrive the goal of the beam size or particle distribution diagram to verify whether my phase space file is read correctly.
Thanks for your question, have you tried setting in the plot tab 2D projection and fixing the Z axis (by selecting it)?
Here below you see a picture of the result I got:
Then, if you are interested only in the results of a given Z interval, you can tune this manually by changing the extreme values in the two fields to the right of the Z coordinate.
Attached you can find an example (input file, flair file, source routine) with all the changes I mentioned before. I took the liberty of increasing the number of bins on X and Y in the USRBIN card to have a more detailed result (although this increases the plotting time).
