I made a model of a surface activity probe in order to score energy.
I used FLUKA version 4-0.1 and FLAIR version 3.1-4.
Geometry model seemed to be OK, but when I launched the simulation, the running immediately stopped and the out file said: “ignoring input” - see, please attached printscreen.
I am sending the flair and input files as well.
Could somebody, please, find what went wrong with the simulation?
Similarly, it is not necessary to fill the material number, FLUKA will automatically assign one.
A low energy neutron cross section data set has to be assigned to each element. FLUKA will try to do it automatically by matching the name of the element with the names in the cross section database. (See: https://flukafiles.web.cern.ch/flukafiles/manual/10.4.1.2.html) If FLUKA can’t find one, or you want to use a different set of cross sections data (different temperature / self shielding) you need to use a LOW-MAT card to make the association. (See: https://flukafiles.web.cern.ch/flukafiles/manual/LOW-MAT.html)
Furthermore, there is a warning in the error file for the use of the deprecated body WED for the region of klin. This can lead to accuracy issues, and it should be replaced.
P.S.: The /usr/bin/nohup: ignoring input is not an error, it is the standard message of the Linux command nohup. It allows to run FLUKA in the background.
