Target is disk with radius 0.6cm and thickness 0.1cm. Why in the _sum.lis file Volume equals to 1 ? Here are .inp and _sum.lis files.
photonuc_21_sum.lis (2.2 KB)
photonuc.inp (1.7 KB)
Dear Sergey,
FLUKA does not calculate the volume of regions automatically. If you want the normalization included in the FLUKA results, you need to manually specify the volume on the RENUCLEi card using the field Vol [WHAT(6)].
Hello,
if needed you can use FLAIR’s functionality to evaluate the volume & surface of complex regions. Just select the region and click on the “volume” icon on the toolbar (see below).
Cheerrs
Chris
