I got a problem when I tried to insert the geometry cards in a *.geo file through the GEOBEGIN card.
It is a simple geometry in the original *.inp file.
I copied the geometry cards between GEOBEGIN and GEOEND and write them into a new gt3.geo file as shown below:
Then I changed the original *.inp file as shown bellow to insert the geometry file using WHAT(3) in GEOBEGIN card.
After saving the input file in FLAIR, I found the content of gt3.geo file had been changed into
I am confused how to pass the geometry file correctly through WHAT(3) in GEOBEGIN card. Will you help me out?
@Jungle it seems your gt3.geo it doesn’t have the proper format. It is missing one line before the * Black body
which should contain the title as well two integers with some legacy information.
The easiest way to create a .geo file from an existing input
by changing in the GEOBEGIN card
the Geometry: Unit to anything different than 5
set a File: name (of a non-existing file)
Then on saving flair will save the geometry to this external file.
