Hello,
I’ve recently updated FLUKA and flair and when running the check_fluka.py I get the following error -
Program received signal SIGABRT: Process abort signal.
Backtrace for this error: #0 0x7f6a34223ad0 in ??? #1 0x7f6a34222c35 in ??? #2 0x7f6a33e4251f in ???
at ./signal/…/sysdeps/unix/sysv/linux/x86_64/libc_sigaction.c:0 #3 0x7f6a33e96a7c in __pthread_kill_implementation
at ./nptl/pthread_kill.c:44 #4 0x7f6a33e96a7c in __pthread_kill_internal
at ./nptl/pthread_kill.c:78 #5 0x7f6a33e96a7c in __GI___pthread_kill
at ./nptl/pthread_kill.c:89 #6 0x7f6a33e42475 in __GI_raise
at …/sysdeps/posix/raise.c:26 #7 0x7f6a33e287f2 in __GI_abort
at ./stdlib/abort.c:79 #8 0x7f6a34221335 in ??? #9 0x55f88ebdd886 in ??? #10 0x55f88eac5150 in ??? #11 0x55f88eac3a30 in ??? #12 0x7f6a33e29d8f in __libc_start_call_main
at …/sysdeps/nptl/libc_start_call_main.h:58 #13 0x7f6a33e29e3f in __libc_start_main_impl
at …/csu/libc-start.c:392 #14 0x55f88eac5044 in ??? #15 0xffffffffffffffff in ???
Aborted (core dumped)
File “/home/check_fluka.py”, line 712, in
with open(“fort.11”,“r”) as f:
FileNotFoundError: [Errno 2] No such file or directory: ‘fort.11’
All other checks passed successfully: python, python tkinter module, tk library, python imaging, gnuplot, memory, CPU, X11, flair, flair-geoviewer, gfortran (version 11.3.0) and FLUKA
Running on Ubuntu 22.04
Thank you
Lior
the error appears when the script tries to built a custom fluka executable named testfluka and run an input that contains only a STOP card inside.
It seems that the testfluka is generated but for some reason it cannot run. To verify the problem can you manually execute the following instructions ($FLUKA is the path where fluka is installed)
