Halo every body
I’m update fluka to fluka 3.2.0 but when I want to update to flair 3.2 I’m downloaded flair 3.2.0 and installed it and flair geoviewer 3…2.0
but when i want to lunch flair form terminal
this message appeared with me
Regarding your last screenshot, you need firstly switch to Python 3 or try to use ipython3 command
Then execute ipython commands in the order that was mentioned
i Downloaded flair
/home/walaa/Downloads/flair_3.2-0_ubuntu18.04_all.deb
/home/walaa/Downloads/flair-geoviewer_3.2-0_ubuntu18.04_amd64.deb
then installed it by using the command
Type the command $ sudo apt install flair
and flair together with all its dependencies will be installed (including flair-geoviewer, dicom etc…). The system updater will notify you for new versions.
Update
To update the flair version either use the update-manager from ubuntu or from the command line
$ sudo apt update $ sudo apt upgrade
and another time by using the command dpkg -i flair_X.XX-X_all.deb flair-geoviewer_X.XX-XX_[amd64].deb
