I have installed FluDAG in order to work with complex geometries. The next step is to install the Cubit plugin, however, I am not able to run Cubit through the terminal. In particular, it doesn’t seem to work with XServer as FLAIR. Did anyone have some experience with Cubit?
After installing the required packages listed in the readme.txt file I was able to run the Coreform Cubit in WSL installed from the tgz package, using MobaXterm as XServer.
You may try to install the Windows version or contact the developer of Cubit is you still have installation issues at
