Is there a way to transfer the geometry from FLUKA to ANSYS
I’m doing some geometry optimization simulations with FLUKA.
The geometry in my simulations is pretty complicated.
Afterwords I need to re-build the geometry of FLUKA simulations in ANSYS.
But it’s really time consuming. Is there a way to convert the geometry from FLAIR to ANSYS directly or is there other way to go?
Thanks in advance.
Qi Ding
Dear @qding
you can do it (with some limitations) through flair.
You can export from flair the fluka geometry to mcnp format
which you can import it to ANSYS workbench.
And you can even do it the other way around, but as I said with several limitations on the bodies that can be used
