FLUKA: fluka4-5.1
Flair: flair-3.4-5.2 and flair-geoviewer-3.4-5.2
Operating system: macOS Sonoma 14.5 (Apple M2 Pro)
Compiler:
- xcode-select --version: xcode-select version 2408
- gcc --version: gcc (MacPorts gcc13 13.4.0_1+stdlib_flag) 13.4.0
- python --version: Python 3.13.7
I am currently experiencing an issue when running FLUKA with a .bmesh file on my laptop. When I attempt to run FLUKA with a .bmesh file, the program fails to load the file and produces the following error messages:
>e> ERROR: unknown file format
STOP Could not load umesh
STOP STOP: FLUKA ABORTED
Error loading umesh “../transition_1-26.bmesh”
Abort called from VXLINP reason Could not load umesh Run stopped!
I noticed that when FLUKA runs, it creates subfolders (e.g., fluka_XXXX), but the .bmesh file is not copied into these subfolders. As a result, it appears that the file cannot be found or loaded.
To address this, I modified the .inp file so that it references the .bmesh file located one directory level above. This approach works correctly on our cluster computing system. However, the same setup does not work on my laptop.
I would greatly appreciate any guidance or suggestions you may have to help resolve this issue.
Thank you very much in advance for your time and assistance.
Jihee
