Dear Expert,
We are performing a simulation to study energy deposition inside a scintillator stack. The photons of interest are produced by the interaction of an electron beam with a tungsten target, with a 3.5 cm thick aluminum stopper placed after the target to stop electrons. Our aim is to observe the photon-induced energy deposition (E_dep) in each crystal of the stack.
Here’s a summary of the two cases we simulated:
1. Photon Beam (Benchmark Test)
First, we simulated a monoenergetic photon beam of 500 keV (no tungsten, only the aluminum stopper) in FLUKA. We scored the region-wise E_dep in each scintillator crystal using the USRBIN card. The same setup was also implemented in Geant4. The results from both simulations were in good agreement in terms of energy deposition values.
2. Bremsstrahlung Photon Generation
Next, we attempted to simulate bremsstrahlung production:
- In FLUKA, we added a 3 mm thick tungsten target before the aluminum stopper and sent 1e8 electrons onto the target.
- We scored the energy deposition in the crystals using a USRBIN (region-wise) card.
- Additionally, we included two more USRBIN cards to monitor photon and electron fluence separately.
However, the results showed almost no particles reaching the crystals and very low or negligible energy deposition, unlike in the Geant4 simulation (run with 1e9 electrons), where we observed reasonable E_dep from bremsstrahlung photons.
Due to FLUKA estimating around 7 days for 1e9 electrons, I chose to simulate with 1e8 electrons, which took aroung 2 days. Still, the large discrepancy (around 3 orders of magnitude) in E_dep compared to Geant4 is puzzling.
My question is:
Is there something I might be missing in FLUKA with respect to the correct setup or physics processes for bremsstrahlung photon generation and transport? Are any additional cards or settings required to ensure proper bremsstrahlung simulation?
3. In this simulation, I also reduced the size of the blackbody and void volumes into a smaller rectangular slab shape.
Could such a modification affect the photon transport or simulation behavior in FLUKA? I am particularly wondering if this could limit bremsstrahlung photon propagation into the scintillator region or unintentionally absorb/interfere with them.
Thank you in advance for your guidance.
cali_new_setup_temp.inp (7.1 KB)
cali_new_setup_temp.flair (6.5 KB)
Shubham Agarwal
