Killing fission neutron
FLUKA: 4.5
Flair: 3.4-4
Dear Fluka expert,
I am trying to recognize and kill neutron from fission.
For this purpose, I am trying the following in a mdstck routine:
  IF (LFSSSC) THEN
     DO IP = 1, NP
        IF (KPART(IP) .EQ. 8) THEN
           WEI(IP) = 0.0D0
        END IF
     END DO
  ENDIF
But it does not seem to work since I still see new neutrons generated.
I have also tried to flag those particles in the mdstck routine and kill them in a usrmed routine as follows but I don’t get any better:
  IF (KPROJ .EQ. 8) THEN
    IF (ISPARK(1, NPFLKA) .EQ. 99) THEN
     WTSCO = 0.0D0
    END IF
  END IF
Additionally, I noted that it seems to behave quite differently if I activate or not the pointwise cross-sections.
Is there something I am missing or is this not possible ?
Thanks for your help.
Thomas
Hi Thomas,
did you switch to 4-5.1?
Your mdstck.f logic should now work in the recommended pointwise mode thanks to the bug fix documented in the RELEASE-NOTES after being triggered by a forum post of 4 months ago.
